David Brown 990 Implematic
David Coonan
07-07-2003 05:25:47
Dear All,
Did DB (or aftermarket) provide any live (engine driven) Hydraulic pumps for these tractors as there is a blanking plate on the engine where a drive gear could mesh into the fuel injection pump? If so does anyone have any parts listing or even a second hand drive grear so I could look at setting one up. Live hydraulics (at a reasonable price)would really make a good tractor great. Thank you.
Regards David from Aust.
rod
07-08-2003 04:15:38
 Re: David Brown 990 Implematic in reply to David Coonan, 07-07-2003 05:25:47
There was a pump for power steering that bolted on just above the injector pump you will see four bolts and a cover plate now my DB 990 has live hyd it is a 1961 red 990 implematic the PTO turns independent of the transmission also on the left side of my housing is a remote valve hook up for using cylinders and such. Drop me an email if you need more info I have the manuals copied
regards
rod
