RIMS FOR CASE LA
jeff
07-06-2003 19:50:14
I'M LOOKING FOR 14" OR 15" X 28" BACK WHEEL RIMS, MY TRACTOR HAS 15" X 30" RIMS AND I BLEW A TIRE LAST WEEKEND AND ALSO IT SETS UP TO HIGH IN THE REAR END,SO I WOULD LIKE TO CHANGE TO 28" RIMS,DOES ANYBODY KNOW WHERE I CAN FIND THOSE
Vern Iowa
07-07-2003 14:43:55
 Re: RIMS FOR CASE LA in reply to jeff , 07-06-2003 19:50:14
Jeff, I have a LA also with the 30" rims. Im not sure whether 28' rims are available for the la. The hub would have to be changed for it would be to big. My question to you would be if I put 18.4 x 30 tires on the 15" rims will they rub on the inside of the fender?
jeff
07-07-2003 19:47:05
 Re: Re: RIMS FOR CASE LA in reply to Vern Iowa, 07-07-2003 14:43:55
VERN FROM IOWA YES THEY DID MAKE 28" RIMS FOR CASE LA AND YOU DIDN'T HAVE TO CHANGE THE HUB,MY BOOK SAYS THEY MADE A 14 X 28,14 X 30 AND A 15 X 30 ALL ON SAME HUB. MY TRACTOR SETS UP SO HY IN THE REAR END THAT I WOULD LIKE TO LOWER IT.WETHER A 18.4 X 30 TIRE WILL FIT,IT DEPENDS ON WHAT FENDERS YOU HAVE IS THE ANGLE IN FRONT OF FENDERS STRAIGHT OR DOES IT HAVE A BEND IN IT TO RAISE THE FENDERS UP,THE TRACTORS THAT HAD HYDRAULIC BRAKES CAME OUT WITH RAISED FENDERS, IM HAVE STRAIGHT ANGLE IRON AND I DON'T HAVE HYDRAULIC BRAKES BUT I DO HAVE 15 X 30 TIRES ON IT AND THAT IS THE SAME AS NEW 18.4 X 30,I HAVE ABOUT 1" CLEARNCE ON TOP AND ABOUT THE SAME INSIDE,BUT IAM AFRAID IF I WOULD GET IN MUD THEY MIGHT RUB FENDERS OR WRINKLE THEM UNDER. THE TIRES ARE VERY CLOSE AND I DON'T THINK IT LOOKS RIGHT THAT IS WHY I WANT TO CHANGE TO 28" RIMS OR 14" X 30" TIRES. JEFF
Vern in Iowa
07-08-2003 06:20:29
 Re: Re: Re: RIMS FOR CASE LA in reply to jeff , 07-07-2003 19:47:05
Jeff, I have a pair of 14.9x30's that are used and I dont know if I should put them on, or the 18.4's. I thought the 14's would be to small and the 18's s to big, like you said. Maybe 16.9x30. Dont go to small or it will make the tractor look wimpy.:) Im glad you told me about the fenders, I do have hydralic brakes which are a pain to fix the wheel cyl. The master is alright, but to fix the wheel cyl, you have to pull the hub. I did both of mine and glad its done. Thanks for the information. Vern
jeff hartke
07-08-2003 16:22:47
 Re: Re: Re: Re: RIMS FOR CASE LA in reply to Vern in Iowa, 07-08-2003 06:20:29
VERN YOU MUST BE ABLE TO READ MY MIND,I FOUND A SET OF 16.9 X 30 MONDAY EVENING AND I;M GOING TO TRY THEM. THANKS FOR INFO JEFF FROM ILLINOIS
Vern Iowa
07-08-2003 06:43:41
Just a second thought. Are you in Iowa? Are you looking for used or new 30" rubber? If you are looking for used, some of the front wheel assist tractors use the 14.9 and the 16.9 tire. They should be available. The tread would be of the newer design. Vern
