2590
COWMANSAM
07-06-2003 06:10:33
WHAT WOULD IT TAKE TO FIX A 2590 WITH THE REVERSE GEAR OUT OF THE TRANSMISSION?
mEl
07-06-2003 16:02:15
 Re: 2590 in reply to COWMANSAM, 07-06-2003 06:10:33
The c-4 clutch in combination with c-2 clutch provides reverse in all rps 34 power shifts. If all forward shifts are proper then there is a malfunction with c-4. ?? is the spool on the rps valve going full into reverse detent?? have you installed a gauge into c-4 test port on the rps valve and tested for pressure both in reverse and in clutch depressed mode?? Do you hear the planetary sing when the clutch pedal is depressed?? these are things we need to know if we are to help you along on this project. mEl
