Fan belt
Joseph M.
07-03-2003 15:32:04
I can't get the fan belt off. I loosened the two nuts by the fan I made the belt loosen a little but I can't make it move enough to take off the belt. Do I need to take off the radiator? Will that help.
Can anyone help me!!
Paul f
07-03-2003 17:21:42
 Re: Fan belt in reply to Joseph M., 07-03-2003 15:32:04
Joe...Is this the 1950 D ?? (It helps to know the model). If it is the D then there are 3 threaded studs with nuts on the fan pulley hub. loosen the nuts and you can twist the hub which will separate the pulley shives (sp?) (you can see the grooves that the studs will move through) That lets the belt settle closer to the shaft and so loosen you can work it off the crank shaft pulley.
Joseph M.
07-03-2003 22:04:03
 Re: Re: Fan belt in reply to Paul f, 07-03-2003 17:21:42
Yes it is 50' Model D. (it needs a lot of help) I Did loosen the nuts And it didn't move so I use some WD on it. The next day I was able to move it a little but after that it will not move the rest of the way. So I can't take off the belt. I don't think I can take off the belt.(don't know what else to do)
Bob
07-04-2003 00:03:41
 Re: Re: Re: Fan belt in reply to Joseph M., 07-03-2003 22:04:03
If you really can not get the belt off, take the radiator off. Undo the bottom radiator hose, and the pipe into the top tank of the radiator, then the two bolts at the side of the radiator.
Lift the radiator off (probably need a second person to help with the lift). You will be able to get at the fan properly and maybe able to pursuade the hub to loosen. If not, the next step it to remove the water pump.
None of these steps are difficult. If you do not have to remove the water pump it should take a couple of hours. Always a bit hesitant to remove water pump as there will often be a further repair to it.
