SC case
Scott KY
07-03-2003 04:44:01
My 49 SC leaks gear oil around the covers on the sliding gear shaft on each side of the transmission housing. My parts book shows an O ring and three shims between the cover and the transmission case. I cannot find a groove or any place for the O ring. Anyone familiar with this problem?
GA. Kern
07-03-2003 11:31:13
 Re: SC case in reply to Scott KY, 07-03-2003 04:44:01
My problem exactly. I have a parts manual and I do not see an O-ring pictured. I have a similar probelm on the belt pulley shaft and leaking from there. Sorry, I don't have a solution, but someone must have "fixed" this problem out there. Iwant to get mine stopped before I paint. It would be easy to make a gasket for those areas, but would gasket thickness throw adjustments off? Curious.
klyde
07-03-2003 16:01:40
 Re: Re: SC case in reply to GA. Kern, 07-03-2003 11:31:13
Yes. Gasket thickness will throw off bearing shim adjustments. Olden days we painted shims with shelac when assemblying them now a days you use RTV or three-bond works as good or better.
