New to Case with SC
G. L. Perry
07-01-2003 21:24:00
Hi Guys! I'm new to Case, bought an SC today. I usually have MM's. A couple questions about tractor. This unit has a pedal by the PTO, I thought to start it, but found that lever more forward now. This has a bellcrank like thing under guard, to left of PTO that is turning. Is this pedal and bellcrank a "lift"? Something like the lift that I had on my Oliver? It doesn't seem to stop turning when I turn the Pto by hand though. My oliver used to trip,turn, stop. this one doesn't by hand anyway. Tractor isn't running yet, so not sure what happens then. Also, for oil level, fella said the two plugs down on side of pan are oil level holes. One for oil, one for oil w/filter change higher up. Zat right? No dipstick?? I found a filler cap on the dist drive area. This tractor has no air filter or canister on it. Is that a hard item to find? I'll have to look at pictures to see what's supposed to be there. Also, the exhaust has a cast elbow on it's top and some broken bolt flanges towards rear on side of tube outside of hood. What's the idea of those? A muffler could slip on the tube, (not there now), but wonder if it's supposed to bolt on when new or ??? I'll be here asking more questions when I get it home and work on it. MM to Case, mean I'm going to "Dark-Side"?
C. Amick
07-02-2003 14:11:22
 Re: New to Case with SC in reply to G. L. Perry, 07-01-2003 21:24:00
I know a little about MM's as well I have an RTU sitting in my tractor shed. I think Case called the mechancal lift a "motor lift". If you had the proper implement, you could probably use it. I think it would work well for plowing. I bought radiator drain cocks at the auto parts store to replace the oil pan plugs. I don't have any spare air cleaners, but I might be able to find one for you. The air intake pipe is supported by the exhaust elbow. There are 2 pieces of metal that clamped around the intake pipe and attached to the exhaust elbow. The muffler just clamps to the upper part of the elbow with a muffler clamp.
jal-SD
07-02-2003 06:15:42
I have an SC that originally ran on disolate. The manual says that you are supposed to drain the oil down to the bottom plug & then fill it to the top plug after so many hours of running time-I don't remember the # of hours. This is because the disolate that "escaped" past the rings diluted the engine oil and you had to drain off the lighter disolate from the top of the crankcase. You were supposed to do this after the tractor had sat overnight. You then filled the crankcase to the top plug. I put a copper shut-off valve in my top plug hole & just open it to check the oil-if it runs our, its good to go, if not pour oil in slowly until it does. These old engines are vary forgiving & don't care if they have too much oil. (My $0.02 worth. jal-SD)
Jim Handke
07-02-2003 05:53:43
The two plugs on the pan are oil levels. If the oil runs out the bottom one when you crack it open, oil level is fine. If it doesn't run, remove top one and add oil until it starts to run out the top hole. The pedal and bellcrank were a lift, before eagle hitch was added to the tractors. Step on the pedal to raise, step again to lower. This ran off the pto. Disengage the pto and the lift was negated. The muffler slipped on the exhaust flange, or a straight pipe like my brother put on his CC.
JM
07-02-2003 05:27:50
I have both breeds, you'll be suprised how much the two have in common. I have been known to use MM parts on Cases.
Joseph M.
07-01-2003 21:46:23
Case is not the "dark side" its the kick *** side. (sorry about that one word!!)
