Dealership has
Les...fortunate
07-01-2003 12:29:34
a set of sleeves and pistons for the SC. Only need one. Think I should swallow hard and buy the whole set?
Jcmarleau
07-02-2003 20:44:37
 Re: Dealership has in reply to Les...fortunate, 07-01-2003 12:29:34
No Les i am not from la belle province i had ACase Dealership for 37 years in Ontario Canada about 45 miles east of Ottawa the nation capital Jean claude marleau
jal-SD
07-02-2003 06:27:40
Les, I THINK original pistons in a '44 were cast. Aluminum ones weren't available until sometime in the '50's, at least not for IH, which I grew up on during that era. I think Case was the same, will check w/BIL, he'll know, his dad bought a '46(?) new & they rebuilt it several times during its life. I don't think that those are the original pistons, probably been rebuilt at least once during its lifetime. I'm pretty sure the ones we have are cast. Gonna be gone until after the 4th, so will check when I get back. (Another $0.02 worth. jal-SD)
Mike from Canada
07-02-2003 01:56:08
have you ever bought a GM "TARGETMASTER" engine?
what they do is take an engine casting returned on warranty (lets say it blew #4 piston) remachine that single cylinder .010"-.030" over depending on how bad it was, install an oversized piston, rebuild the rest of the engine w/ stock pieces and resell it to an unsuspecting customer looking for a deal on a rebuilt motor.
if the replacement pistons in this set youre looking at are aluminum, youre gettin a good set. its less weight for that poor old crank to throw around and may up your horsepower a smidge.
just ask yourself this:
do i want a good rebuild or a targetmaster?
mike
Joseph M.
07-01-2003 21:59:00
Go for it buy the hole set
Brian in Ohio
07-01-2003 20:28:39
Wash a few extra dishes for the misses, and maybe fix that broken screen door for her, then go buy the set. If you going to do the job, do it right the first time...
jal-SD
07-01-2003 12:38:26
Yep, I've been told they don't make 'em any more. (BTW, what is he askin for 'em?) In case you decide not too, let us know, we MIGHT have a good one, depending on what bore & piston configuration ya have. Water in our part of the world is generally tough on the back side of 'em, so they usually have lotsa pitts in 'em. (My $0.02 worth. jal-SD)
Les...fortunate
07-01-2003 15:36:10
 Re: Re: Dealership has in reply to jal-SD, 07-01-2003 12:38:26
These are OEM pistons and sleeves. Some over $500 for the set of four. I believe the piston is aluminum and the sleeve is iron (see Sky Bartlett's post below). Would that make sense for a '44?
Tom in Mo.
07-01-2003 15:47:34
 Re: Re: Re: Dealership has in reply to Les...fortunate, 07-01-2003 15:36:10
That's a lot of change but if you really like the SC go for it. Why not treat it to a whole new set instead of just one? Not too long ago I had to give $450. + for just a set of sleeves for a new generation Deere. I vote yes.
