Silicone gasket maker
Joseph M.
06-30-2003 22:08:52
Is it safe and ok to use PERMATEX hi-temp silicone gasket maker (Ultra black) on the exhaust manifold?
Thanks
C. Amick
07-01-2003 12:23:03
 Re: Silicone gasket maker in reply to Joseph M., 06-30-2003 22:08:52
I wouldn't recommend using the silicone for this application. Do you have the old gasket? They make a copper spray that I have used to seal used head gaskets. I'm not sure it will work on exhaust gaskets, though. Might want to ask the guys at the automotive parts store.
Mike from Canada
07-01-2003 07:43:02
umm... personally i dont recommend using silicone for exhaust. coming from an automotive background, generally sealant isnt recommended for exhaust work. gaskets are required if not recommended but i do use antisieze lubricant on bolts and surfaces for added security.
just remember to retighten the bolts while the engine is hot (running) to really seal the exhaust system.
good luck!
mike
