Girard tractor auction June 27th and 28th
Bill
06-30-2003 17:53:20
Did anybody attend this auction? I was wondering what the CH case brought at that auction? thanks Bill
Glenn/Mn
06-30-2003 19:42:41
 Re: Girard tractor auction June 27th and 28th in reply to Bill, 06-30-2003 17:53:20
Case 20-40 Manual brought $750 + 10% buyers premium, was not able to attend saturday pole barn project is under way.
511-B-L
06-30-2003 19:55:32
 Re: Re: Girard tractor auction June 27th and 28t in reply to Glenn/Mn, 06-30-2003 19:42:41
I think it sold for $5,000 or $5,100. It didn't impress me very much. It looked like any other C case, except it had taller rear tires.
John H-WI
06-30-2003 20:52:43
 Re: Re: Re: Girard tractor auction June 27th and in reply to 511-B-L, 06-30-2003 19:55:32
Only 7 made. If I had the bucks I would have gone higher to get it.
Glenn/Mn
07-01-2003 05:51:54
 Re: Re: Re: Re: Girard tractor auction June 27th in reply to John H-WI, 06-30-2003 20:52:43
I told dad what it brought, all I got was a blank stare. He figures peopole ought to pay me to show up even if I don't bid everything goes sky high
Glenn/Mn
06-30-2003 20:00:48
Should have had 14" clearance on the front axle as well, I would have expected it to go higher
Bill
07-01-2003 14:33:59
 Re: Re: Re: Re: Girard tractor auction June 27th in reply to Glenn/Mn, 06-30-2003 20:00:48
The reason I asked is that I own a CH. I dont have the serial numbers handy for the seven but there is over 180 CH tractors out there that case refitted at the factory as ch,s None of the seven have come to life that I know of. If that was a refitted case I would think that the new owner may be wishing he checked out the serial number first before bidding. The only real difference in them is the spacer block to get the ground clearance on the front axle and the spindles are a little different. Bill
Glenn/Mn
07-01-2003 19:10:00
 Re: Re: Re: Re: Re: Girard tractor auction June in reply to Bill, 07-01-2003 14:33:59
How is one to know the difference between the true (7) CH's and the factory conversions
Bill
07-01-2003 19:48:04
 Re: Re: Re: Re: Re: Re: Girard tractor auction J in reply to Glenn/Mn, 07-01-2003 19:10:00
A person by the name of Tom Graverson did reearch on this subject and came up with the seven serial numbers of the tractors that case built as ch,s then added up all the cc,s and c,s that were brought back to racine and refitted as ch,s The seven serial numbers were listed in one of the case mag. The data stated that the ch had no turning brakes but thats hard to say how the customer ordered them.Mine was a cc then refitted as a ch at racine in 1938. Having a copy of the build card will tell the story of each tractor, and that you can get from Racine. Sorry for the long post. Bill
Glenn/Mn
07-02-2003 06:50:54
 Re: Re: Re: Re: Re: Re: Re: Girard tractor aucti in reply to Bill, 07-01-2003 19:48:04
Thanks for posting the answer, should help everyone in the future.
