David Brown 990 Electrical Problem: help please!
Ritchie Leslie
06-29-2003 18:44:45
Working in the field today, ignition and hydraulic filter warning lights suddenly came on and stay on at any engine RPM. Oil pressure light and all other electrics work normally.
Generator was replaced about 5 yrs ago with a rebuilt unit. Have also noticed that battery was not charging properly for a while before this.
Anyone any ideas what might be wrong? Have I lost another generator or could it be the regulator this time?
Elmer
06-30-2003 15:27:14
 Re: David Brown 990 Electrical Problem: help pleas in reply to Ritchie Leslie, 06-29-2003 18:44:45
There is a diode between the two circuits. It may be bad. I have them in stock.
Ritchie Leslie
07-04-2003 06:58:00
 Re: Re: David Brown 990 Electrical Problem: help p in reply to Elmer, 06-30-2003 15:27:14
Elmer:
What is your email? If I have to remove the instrument panel to replace the diode I might as well replace the voltage regulator at the same time as I suspect I still have the original in place.
I've tried calling you several times.....
Thanks
RL
