Need advice on Case 730/731
RiverValleyFarm
06-28-2003 19:05:29
Hi there - please help - haven't bought a tractor in years, could use some good advice. I want to buy a Case 730 diesel, draft-o-matic (hood says model 730, on engine it says 731 - whay is that? new hood maybe? what does draft-o-matic mean?) everything seems to work ok, except hydraulics. Tractor has been sitting for 1 year, hyd are slow to respond (front bucket & 3 pt hitch) it has 4451.6 hrs on clock, shifting through gears ran ok, no leaks in the wrong places, looks in good condition, drove well. The price will be $3500 as is or if owner can fix hydraulics, new battery & some new hoses, it will be $3995 (in my price range). Does this sound like a good price to you guys? I like this tractor a lot and want to buy it, but don't want to get "stuck" by not being able to find parts or get it repaired easily, since grease is just not my thing...Thanks a bunch!!
rivervalleyfarm
07-01-2003 15:03:26
 Re: Need advice on Case 730/731 in reply to RiverValleyFarm, 06-28-2003 19:05:29
Thanks to all!! I'm picking it up on Thursday - $3500 and I do the work ( will definitely change fluids and filters immediately) and my new Case "horses" and I will get to work. Thanks again- I really appreciate all of your input!!
Jim Handke
06-30-2003 05:17:41
I paid $3500 for my 830 CK years ago and they still bring that same price. And you can find some 1030's for about the same price. The question is, do you need the extra horses and weight?
John H-WI
06-29-2003 07:04:11
If you like the tractor go for it. They have been a very good unit. Brother had one and I think it was one of the better units Case built for its size. He had 4800 hours on it and never touched the engine. Guy that bought it parked his 4010 and used the 730 on the chopper cause he liked driving it better. The ComfortKing series had the platform raised up so you could see better and you got on from the side. Just my personal opinion but the CK was a much nicer unit to drive. Have the guy fix it and buy it.
keith
06-28-2003 19:28:07
I have a 1968 730 comfort king diesel that I bought last year for 3500 I use it for haying and really like it. as for some of your questions Draft o matic is the type of 3 point system That case used. If you buy it get a manual it will tell you all about it. 731 on the engine indicateds it is a diesel with standard clutch. Different #s indicated different versions of the 730 gas,diesel,case-o-matic,etc... I would say if you like the tractor buy it I've seen some sell for more and some for less. I also would let him fix the hydrolics and replace the battery at that price I think that a rebuilt pump alone will cost you $300. And finally I have not had a problem getting parts I have gotten most of them from my local caseih dealer and some from aftermarket companies.
Jeff
06-28-2003 19:13:31
That's a High Price!!!!! Heck for that price you can buy a Case 1030 CK.
RiverValleyFarm
06-28-2003 19:17:49
 Re: Re: Need advice on Case 730/731 in reply to Jeff, 06-28-2003 19:13:31
How big is that? Where would I get one? I'm in the Western MA/ Northeast NY / Vermont area. Tractor prices are usually a lot higher than that here.
RiverValleyFarm
06-28-2003 19:09:37
BTW it is also a Comfort King (what does that mean?)
Phil Munson
06-29-2003 08:26:42
 Re: Re: Need advice on Case 730/731 in reply to RiverValleyFarm, 06-28-2003 19:09:37
Thanks for the additional info; it is needed. The price is plenty, but more inline for the comfort king than an eagle hitch. The comfort king platform sets you above and in front of the rear axle. The eagle hitch sets you behind the rear axle, and lower than the CK, more like an IHC M. I have an old 800D, with over 15K hrs on it. The 800 is the forerunner of the 730 eagle hitch. Parts are not a problem, and frankly, your hydraulic problem is probably a need to change the hydraulic filter. Don't offer too many $$$ for that.
