Two tranny questions
Joseph M.
06-28-2003 13:53:04
First what kind of transmission oil should I use for a model D. Which one is the drain plug?
Thanks!!
Paul f
06-28-2003 16:54:05
 Re: Two tranny questions in reply to Joseph M., 06-28-2003 13:53:04
Joe: Transmission/rearend fill Takes 10.5 gal of GO 90 (SAE 90w for civilian types) There are two drain
plugs on the right side...One just ahead of the brake drum, second is about
six inches rear of brake pedal pivot. Fill is on the top left rear
corner...be careful if your tractor has hydraulics the two fill points are
close together... Trans is the more forward of the two and larger. Fill till
it runs out the trans level plug (back on the right side under the rear of
the foot platform)
