Where is the DRAIN PLUG for Case VAC Transmission?
Ron
06-28-2003 10:16:50
Hello: I want to change the Transmission geer oil which the owners manual said it takes 7 gal. of SAE#90 geer oil.I have a Case VAC with eagle hitch and want to change the oil in the torque tube also which the book said 8 qts. of sae #10 oil I cant fine the DRAIN PLUG for the transmission. I think the torque tube drain plug is rite under the torque tube but where is the drain plug for the transmission???
Thanks Ron
Steve from PA
06-28-2003 17:04:02
 Re: Where is the DRAIN PLUG for Case VAC Transmiss in reply to Ron, 06-28-2003 10:16:50
I agree with Joe. The drain plug is on the very bottom of the largest part of the axle housing and the plug on mine was screwed in far enough that it couldn't be seen unless you were lying on the floor looking up at it.
Joe (Wa)
06-28-2003 16:50:37
Transmission drain plug is just forward of and slighlty left of center of the trans/axle flange. Probably a 3/4" pipe plug with 1/2" recessed square for wrenching. Torque plug is just forward of trans/torque tube flange, right side. Might want to check the hyd filter while torque tube is drained, left side 4 bolt flange (clutch rod pivot may be connected to this flange) under fill plug. Joe
