Radiator
Joseph M.
06-27-2003 08:50:15
Does anyone know how to get all the rust out of a radiator because my radiator is a rust bucket. I'm wondering how long my radiator will last.
Thanks!!
caseman-d
06-27-2003 19:49:48
 Re: Radiator in reply to Joseph M., 06-27-2003 08:50:15
What model of tractor is it, some of them you can pull the top tank and bottom tank off like the D series tractor. If you radiator is really bad I wonder what the iside of your block is like. I have a Case D sitting here that has rusted out sleeve. So be careful and flush the block before fixing the radiator. If the block is full of rust you will fill the radiator back up with rust. Good Luck
caseman-d
Joseph M.
06-27-2003 22:21:47
 Re: Re: Radiator in reply to caseman-d, 06-27-2003 19:49:48
It is a model D. I flushed the radiator clean but it gets rusty water when I run it.
Thanks!!
caseman-d
06-28-2003 18:04:15
 Re: Re: Re: Radiator in reply to Joseph M., 06-27-2003 22:21:47
The top and bottom tank can be removed on the D radiator, if it's just the rust clolr your worried about I beleive NAPA has a additive you could put in with the water. I would run straight water with the additive in it this summer before adding anti-freeze for the winter time.
caseman-d
