DC in IN
Mike from Canad
06-26-2003 10:13:08
well, im not sure what to say about this one. its a fixer-upper, converted to 12V w/ no i.d. tags and a cosmetically cracked block. but hey, it starts @ $250! reason enuff to be curious.
feast yer eyes!
mike
ron bond
07-04-2003 18:57:45
 Re: DC in IN in reply to Mike from Canada, 06-26-2003 10:13:08
I just bought a case DC ser 8023422 in ontario- peterborough- for 500.00. It is complete with a "V" blade snow plough. No eagle hitch. can you tell me a value- and where can I find a manual as I want to hear it run. what qualities did the dc possess, I would like to know about the tractor.
Don Rudolph
06-28-2003 10:09:02
Just returned from Central IN with a 52 DC LP for parts. Was in about the same condition as the one pictured. Hey Don L, we need those fenders bad!!!
David
06-27-2003 17:36:42
Hello Mike,
Thanks for the link.
I need tires bad. My 41 engine doesn't have an oil filter. The weights(only yesterday, I mounted the Farmhand loader) and other stuff for spares are a +. My homemade 3 point is only working for the post hole digger, so the eagle hitch would help there. If it had nice fenders, that'd be everything I need.
Will the wheels from the late, narrow front fit my 52 DC4?
Best Regards,
David
Larry
06-26-2003 18:20:30
I guess I should bid on this one as I am located in central Indiana. It looks like it is complete with eagle hitch and weights. I have a 49 DC that I have restored and this one might be a good add.
Ted in Sacramento
06-26-2003 16:23:42
I prefer the DO in FLA, guess I'm partial to Orchards but it is looking mighty fine, if it was close I think I would be a bidder, any guess on what it might cost to put on a wagon train headed West?
Mike from Canada
06-27-2003 19:36:10
 Re: Re: DC in IN in reply to Ted in Sacramento, 06-26-2003 16:23:42
not sure.
early model DCs came w/ 4 bolt lugs on the hubs and late models had the single nut holding the entire wheel at the hub.
if the spindle is the same size then the change over is easy.
good luck!
mike
