Electrical system on dc
steve
06-24-2003 18:12:33
i have converted my 1950 dc case over to a 12 volt system, my question is does the wire go from the side post marked battery to the on/off switch, and does the wire coming out of the plug (hot) go to the amp gauge? something is causing a draw from the battery. thanks for any info
todd
06-25-2003 20:45:37
 Re: electrical system on dc in reply to steve, 06-24-2003 18:12:33
check the following article located on the YT web site - Recommendations for 12 volt Conversions. Skip the first article in the list titled Converting Your Tractor from 6 to 12 volt. The article you want is submitted by Genesee Products and can be directly accessed at>Link
I>Link used these instructions to convert my SC with very good results.
Allan C
06-24-2003 22:30:53
It sounds like you have them reversed. I'm assuming you have an alternator with built in regulator. The big one is the Bat wire which should go to the ammeter, A delco has 2 connections, the closest one to the battery line is for an idiot light, the farthest needs switched power to run the regulator. I assume you know you have to go to negative ground. If you're still using the original pos ground that will kill the battery and the alternator.
I'm making a few assumptions here. If I'm wrong post some more details and we'll sort it out.
steve
06-25-2003 10:25:06
 Re: Re: electrical system on dc in reply to Allan C, 06-24-2003 22:30:53
i have ran the wires the way you think they should be, but the amp gauge is still not showing any reading, how can i tell if it's the alternator or the gauge that may not be working? and you are right, i do have it hooked up negative ground. thanks
