VAO Torque Tube
Ted in Sacramen
06-22-2003 18:14:19
Does the torque tube have any lubricating responsibility or is it simplly a fluid reservoir for a hydralic system. I have a service manual and operators manual and can't noodle it out of them. Thanks
Ted in Sacramento
06-23-2003 16:03:33
 Re: VAO Torque Tube in reply to Ted in Sacramento, 06-22-2003 18:14:19
I have no side pulley, no low pressure or high pressure pumps installed. There is no transfer of fluid from the transmission to the torque tube as the tranny fluid was corrupted and rusty and the torque tube fluid is clean. It is a little low and has sat for at least five years so I will change it out and put in the two gallons SAE 90 required. Thanks
Joe (Wa)
06-23-2003 18:22:21
 Re: Re: VAO Torque Tube in reply to Ted in Sacramento, 06-23-2003 16:03:33
If the shaft seal leaks, fuild will migrate from the torque tube to the transmission as that oil level is higher.
Joey
06-23-2003 08:18:18
Ted,
When you fill the transmission with 80/90 weight oil, you also need to fill the torque tube. Sometimes it fills when the transmission if filled. Regardless of whether or not you have a side pully, the oil is in the tube to lube the end bearings and it certainly won't hurt anything being there, maybe even stop some rust from forming.
mj
06-23-2003 08:14:30
You've got to have the torque tube up to the filler hole (left side) with SAE 90wt gear lube in order to luricate the clutch shaft bearings, whether or not you have a hi-pressure pump and/or belt pulley on the tractor. If you have the low-pressure system then you must keep the level up with the specified oil for the season. The live hydraulic pump is not self-lubricating and will be ruined quickly without oil. If there is no hydraulic system on the tractor at all you still need lubricant for the clutch shaft bearings.....ROGER? :-)
Mike from Canada
06-23-2003 00:21:49
if you have no hydraulics then the torque tube as a reservoir is unnecessary, however, if you have a side pulley (w/o a pump) its required to have oil in it to lubricate the bearings for the pulley.
hope this helps!
mike
Marty
06-23-2003 11:37:35
 Re: Re: VAO Torque Tube in reply to Mike from Canada, 06-23-2003 00:21:49
Pardon me if I am wrong, but does the torque tube fluid not lub the rear end/PTO too ??
Mike from Canada
06-23-2003 23:52:38
 Re: Re: Re: VAO Torque Tube in reply to Marty, 06-23-2003 11:37:35
no. the tranny is a separate unit from the torque tube. the differential/pto is lubricated by the tranny oil.
good luck!
mike
