New to Case/need info
G. L. Perry
06-21-2003 19:53:00
Helped a fella bring home a case tractor today. We don't know model or year. Is there a tag or stampings on it to tell? Where? It has one of those out front wheels that's not under engine. I'm thinking maybe an SC? Has hand clutch, hydraulics off the PTO area, magneto. The battery is now setting above the gauges by steering column. Where's it supposed to be? Positive ground? Hood wasn't with tractor, got thrown away for some reason. This gonna be hard to find?
dave
06-22-2003 18:46:29
 Re: New to Case/need info in reply to G. L. Perry, 06-21-2003 19:53:00
1949 case(d i)core of engineers/us army (brassplates from us army)case ser#219408di Can I get any info about this tractor.
John H-WI
06-22-2003 18:53:25
 Re: Re: New to Case/need info in reply to dave, 06-22-2003 18:46:29
You are missing one digit of the serial number, should be 7, subtract 4 from the first two to get year of manufacture.
Mike Schotte has a copy of a "build" card that can be sent to Case to get info when the tractor was built.
Mike posts regularly here or ask him the question about the card.
dave
06-22-2003 19:01:46
 Re: Re: Re: New to Case/need info in reply to John H-WI, 06-22-2003 18:53:25
ser #5219408 Manufactured Mar30 1949(Guess I missed The 5) dave
John H-WI
06-23-2003 02:21:28
 Re: Re: Re: Re: New to Case/need info in reply to dave, 06-22-2003 19:01:46
Dave, according to the formula you have a 1948 model. Either due a search on "build cards" or pose a question for Mike Schotte. He currently has his email hidden for spam reasons.
John H-WI
06-22-2003 05:47:13
Let us know what part of the country you are from and someone can tell you what salvage yards are around. Hoods shouldn't be too hard to find. Around our neck of the woods Don Livingston is a good guy to work with. In Austin, MN.
Email [email protected] 507-433-0073 mornings best.
If the serial plate is missing look for the number stamped on the block, left side where the block meets the transmission housing. As the other guys said if the battery is above the gauges in front of the steering column its a DC. Go to the tractor photos and do a search on Case and look at the SC DC and you should see what it looks like with the hood.
Larry W
06-21-2003 20:02:12
Well if the battery is above the steering wheel just behind the gas tank, it would be a DC. There should be a SN tag on the dash with the gauges. The steering linkage on a SC is solid steel with the ends larger than the linkage, the DC is the same size all the way.
Butch/ OH
06-21-2003 20:42:41
 Re: Re: New to Case/need info in reply to Larry W, 06-21-2003 20:02:12
A DC would have a cast iron grill and bolted on upper and lower tanks on the radiator. The SC would have pressed steel grill and a one piece radiator.
