SC Case Water Pump
Larry Whitesell
06-21-2003 19:40:47
I have overhauled with new sleeves pistons, completely rebuilt the head and have a problem with foam in the radiator. I thought maybe my head gasket was leaking so replaced it, same problem. My water pump leaks a small amount, could it be sucking air in causing the problem? Where can I get a rebuild kit or a rebuilt water pump?
Mike Schotte
06-22-2003 08:01:35
 Re: SC Case Water Pump in reply to Larry Whitesell, 06-21-2003 19:40:47
Larry,
A suggestion from this board (which I've used on my SC and recommend)is to drill the thermostat flange to allow for some coolant to bypass.
Seems to eliminate the foam and coolant spill over problem.
-Schotte
third party image
Larry Whitesell
06-22-2003 19:04:27
 Re: Re: SC Case Water Pump in reply to Mike Schotte, 06-22-2003 08:01:35
Thanks Mike, however my SC doesn't have a place for a water pump.
evad
06-21-2003 21:25:25
I've got the same problem although I didn't do an overhaul. Pulled the head, everything looked good, sent the head down to have it checked for cracks, they found none. Put new water pump on. Haven't put head back on yet.
