When you have to eat Crow-- how is it prepared?
Jim Handke
06-20-2003 20:07:04
I have bad-mouthed rebuilt hyd. pumps for dad's 970 for 2 years. He sprung for a new one this spring, and it didn't help one bit. You had to run the engine to 1500 rpm to get the lift arms to raise or hyd. cyls. to move. This wasn't pretty trying to plant this spring. So we tore the powershift down and found the oil distributer hub and cover were badly worn, and two broken rings. Got her running now, but not without another problem. We were given the wrong bottom ROPS gasket. Stepping on the inching pedal wouldn't engage C-4, and you had to pull the lever into reverse to get into gear. When you finally got moving, the shift pattern was low, high, and then intermediate. Talk about pulling your hair out. Now we're sleeving a 1070 for a friend. Finally, a paying job.
J.L.
06-22-2003 19:59:55
 Re: When you have to eat Crow-- how is it prepare in reply to Jim Handke, 06-20-2003 20:07:04
When I have to eat crow I prepare it by just being honest with it and tell it "I'm going to have to eat you now"!
Larry
06-21-2003 19:50:02
If your lucky you will have your crow served warm.
But revenge is a dish better served cold.
SHeiserman
06-20-2003 20:45:52
I'd pour melted velveeta over it, really helps with brocolli.
Jim Handke
06-21-2003 14:57:42
 Re: Re: When you have to eat Crow-- how is it pre in reply to SHeiserman, 06-20-2003 20:45:52
Also them little Collie-Flowers.
Mike from Canada
06-21-2003 18:11:49
 Re: Re: Re: When you have to eat Crow-- how is it in reply to Jim Handke, 06-21-2003 14:57:42
i hear crow is prepared well when baked in a nice white "whine" sauce
good luck!
mike
