Case sc pos. or neg. ground, 6 or 12 volt
jason
06-20-2003 20:05:08
I'am working on a case sc and wondering if it is a pos. or neg. ground also if it is 6 volt or 12 volt
how do you know on the type of ground you should have
D Smoker
06-21-2003 09:58:17
 Re: case sc pos. or neg. ground, 6 or 12 volt in reply to jason, 06-20-2003 20:05:08
6V negative ground from factory
JASON
06-21-2003 11:53:18
 Re: Re: case sc pos. or neg. ground, 6 or 12 volt in reply to D Smoker, 06-21-2003 09:58:17
CAN you tell me how the wiring goes coming off the regulater the wire goes to the + side off the ampmeter along with a wire that goes to the pos. side of the starter switch.
- side of the ampmeter goes to the light switch is this correct thanks for the help so far
