Magneto problems
NATHAN
06-19-2003 19:17:28
i have a case tractor i think it is a vac, serial number 5302074. it has the cast iron grille and does not have a pressurized radaiator. i would like to know if you can use a magneto from a allis chalmers w/c? it's a fairbanks morse. i am missing the magneto for mine. the wc mag fits on to my case. does anyone know if it will work and not ruin the magneto?
thanks
nathan scow
nathan scow
06-20-2003 07:13:42
 Re: magneto problems in reply to NATHAN, 06-19-2003 19:17:28
thanks for all the help.
Paul f
06-20-2003 05:26:43
Nathan: It does sound like yours is a D series. Many Ds were converted to distributor, points and coils when the mags failed. Mine has a right angle Delco remy distributor and 6 v coil. She runs great and parts are easier to come by. If you are interested I can go look at the distributor number. From what I have read they came from Farmalls.
nathan
06-20-2003 07:11:48
 Re: Re: magneto problems in reply to Paul f, 06-20-2003 05:26:43
please look at your distributor number. i have a lot of farmall distirbutors.
Paul f
06-20-2003 16:59:04
 Re: Re: Re: magneto problems in reply to nathan, 06-20-2003 07:11:48
Nathan: The distributer is Delco Remy
Model 1111411
Serial 1D2
The right angle base casting has a number 131
Hope this helps
Jim
06-20-2003 04:05:58
If your tractor has a cast iron grill is is not a VAC. Likely a D. The letters that precede the serial number on the metal tag will tell you what model it is, i.e. DC 53XXXX.
Jim
Kennyp
06-19-2003 20:42:54
While I have no experience with a VAC I will say that mags are pretty much interchangeable. As long as they have the right number of cylinders and run the right direction. You will have to figure out the right timing of course
Allan C
06-19-2003 22:30:28
 Re: Re: magneto problems in reply to Kennyp, 06-19-2003 20:42:54
Kenny P is right. Any 4 cylinder mag that fits can be made to work. Some mags are reversable, but that takes some work. The timing in a mag has to do with the impulse delay, so is usually in the ballpark if it's off a similar tractor.
