Water pump for a 400 super
JM
06-18-2003 15:18:52
Is there anywhere cheaper than Case to get a water pump for a 400 super dsl? They said over $300 for one. Mine went out while cultivating corn today.
Gene Dotson
06-19-2003 17:49:42
 Re: Water pump for a 400 super in reply to JM, 06-18-2003 15:18:52
JM;; I repaired the water pump on my 700 diesel. Only needed a new bearing. The bearing is a Fafnir part number 304KLZ. Install with the seal side out and be sure to completely fill the cavity with grease. The seal is a grease pressure seal and normally does not need replaced. Total cost of repair was a little over 12 bucks...Gene
RobertTX
06-19-2003 05:33:35
Someone has been selling new pumps on ebay that fit many models, don't remember if it fit yours or not. Think it was starting around $60.
Greg
06-18-2003 16:28:08
I just bought a water pump for a 700B which is the same as your super 400 for 115.00 through Case. Its a rebuilt pump.
Dale In Tx.
06-18-2003 15:28:26
JM Try A&I Products.com Good luck Dale In Tx.
