VAC info
Steve from PA
06-18-2003 13:30:13
I was recently at a show here in PA and I saw a VAC-14 with 34" rear wheels. Does anyone know if they ever made a VAC with those rear wheels and a narrow front? Also, if anyone knows of a detailed reference book for Case tractors, especially the VA series? Thanks in advance for all your help.
David Pritchett
06-25-2003 10:55:03
 Re: VAC info in reply to Steve from PA, 06-18-2003 13:30:13
I have a 52 VAC with 34" rear tires and narrow front. Original owner said it's the way it came from the dealer in atlanta in 52. Still restoring at this time. Hope to be tearing up ground in several weeks.
wheat straw
06-18-2003 20:50:07
Steve, A vac14 with 34's would be rather uncommon in that there are about four features that make it a vac14; adjustable wide front, low seat, 28 rears and a 12 mph road gear. Take all that away and you have a vac12. However, seems like there is always one of those, some dealers did order the narrow front on the vac14 but i've never seen one with 34's. Don't know why it wouldn't work though as the 9-34's are not as tall as the 11-28. It wouldn't speed up the road gear to much. anyhow, if someone has a 14 with the 34's please post. Always like to see something new.
Wheat Straw
Joe (Wa)
06-18-2003 23:17:13
 Re: Re: VAC info in reply to wheat straw, 06-18-2003 20:50:07
Wheat straw, road gear 14 mph? I have a '51-'53 VAC (13?) that does an easy 30 mph in 4th on flat black top. Is that normal? Joe
Mike from Canada
06-19-2003 09:32:26
 Re: Re: Re: VAC info in reply to Joe (Wa), 06-18-2003 23:17:13
someone must have placed a VAI tranny in there. some hwy dept. models specified a hi-speed travel gear in their tractors.
mike
wheat straw
06-19-2003 05:20:07
Joe, No, it's not normal for a vac. There is a high geared tranny that was used on some of the vai's with 24" rears. Suppose some one stuck one of them in it? Fast tranny and a taller tire would sure make a drastic change in ratios wouldn't it? Case normaly kept everything 10 or under out of safty concern. Be hard to see that one pass by at that speed wouldn't it? Be careful. It could have you off the road and up a tree before you knew it at that speed.
be safe
Wheat Straw
Joe (Wa)
06-19-2003 08:48:49
 Re: Re: Re: Re: VAC info in reply to wheat straw, 06-19-2003 05:20:07
Thanks Wheat Straw, it has 28" tires and Univ of Idaho stickers all over it. Hasn't been in 4TH since I drove it home (about 7 mi) from the seller's place. Joe
John H-WI
06-18-2003 19:06:27
Go to www.geocities.com/mikevickig to see a 55 with narrow front and 34" rears.
Les...fortunate
06-18-2003 16:10:09
My '52 VAC (12) has 34" rear tires.
CASEPOWER
06-18-2003 15:13:15
Yes they did. I have a set on a late model VA. I think it's a 52. Here is a link to the Case Page. The links to the data and pictures are at the bottom.
Steve from PA
06-18-2003 17:43:25
 Re: Re: VAC info in reply to CASEPOWER, 06-18-2003 15:13:15
I must have used the wrong terminology to describe the front end that I'd like to go with the 34" rears. I'm looking for a row crop front like I have on my '47 VAC. Sorry about the confusion. Thanks again, Steve.
John H-WI
06-18-2003 14:06:22
One book you might find helpful and not too expensive is Peter Letourneau's Illistrated Buyers Guide Second Edition. Its aggod starter. Another place to look at is CASEPOWER's web site. He has many of the production numbers plus some photos.
