Was this an Eagle Hitch on this 210B?
Mike Johnston
06-17-2003 13:00:33
third party image
This utility tractor is missing most of the lifting parts for the back end. Is this whats left of an Eagle Hitch? If so, what is the real difference between an Eagle and a 3pt-hookup? Can either be used for disc or box-blade work?
I need to come up with all missing parts for either an Eagle hitch for a 210B or a 3pt hook-up. Is anyone currently parting out one of these tractors or a 300 or simliar?
Thanks in advance for tollerating my questions, and for any parts info.
Mike Johnston
george md
06-18-2003 09:03:46
 Re: Was this an Eagle Hitch on this 210B? in reply to Mike Johnston, 06-17-2003 13:00:33
Mike,
that looks like eagle hitch , top link mount is missing , mounts below tool box . For using rear blade , stone rake , or mounted rotory mower, you will probably like eagle hitch better than swinging arms . when working around trees etc equipment mounted on eagle hitch will go where you want it to go rather than where it wants to go . I still have 3 tractors with eagle hitch .
george
jr
06-17-2003 23:58:44
Yes it was originally
Shane
06-17-2003 17:40:11
I have some eagle hitch parts off a 400 that may work, not sure what all I got so if you need anything just email me. Shane
john
07-09-2003 21:29:24
 Re: Re: Was this an Eagle Hitch on this 210B? in reply to Shane, 06-17-2003 17:40:11
Seeing you have Case 400 eagle hitch parts - do you have a top link? I just got a Case 400 and wanted to cultivate some corn but could not get the scuffler up high enough. Thus it must take a unique top link.
Thanks John
Joe (Wa)
06-17-2003 15:18:01
Same configuration as 311B eagle hitch. That right side lift arm will have a hand operated gear box in the yoke. Look under or right in front of the tool box may have raised letters "EAGLE HITCH".
mj
06-17-2003 14:36:59
It appears to be....If the lift arms you show will cycle up and down (push them down with the valve in 'down' position) then all you need is a pair of draft arms and lift links (one of the links should be adjustable). The attachment brackets on the axle seem to be set up for the Eagle type draft arms which did not allow for side to side to side movement of the arms...personally I prefer the Ferguson style arms with ball-ends....makes hitching up to the implement much easier since a lot of them are not very close to the Cat. I standard dimensions. Sway with these type ends is best controlled with chains mounted outboard of the draft arm axle-mounts but on the same centerline. There is an Eagle hitch shown on my web album....click the link and then click on an image to enlarge. :-)
wheat straw
06-17-2003 14:18:02
Mike, The 200 was the first case to be offered with either the eagle or standard 3 pt hitch. You had a choice with it. however, it still didn't have the draft controll. not many 200 were made and i don't know the breakdown of 3 pt verses eagle hitch in that # but either hitch will work. the draft links were the difference. the eagle hitch draft arms had solid mounted and wouldn't swing side to side and the latch point had a latch system instead of the ball ends like a 3 pt. It's a case of the same thing only different. It still had the three connecting points. Hope you can find your parts. bet these others will interchange. check with Don L who posts on here a lot.
Wheat Straw
