Case top link
dan harrison
06-17-2003 05:18:08
Does anybody know where I can find a top link for a 611 b. The same top link should fit any 500 or 600 series case built in 1958 or 1959.It doesn't have to be an original as long as the tractor end will fit. There is only a little over 1/2 inch of clearance between the pin and the tractor so the after market top links that I have looked at won't work.
mj
06-17-2003 14:49:51
 Re: case top link in reply to dan harrison, 06-17-2003 05:18:08
You could replace the right-hand threaded end of a standard toplink with a piece of All-Thread and weld on a tab made from 1/2" x 1 1/2 or so strap. Drill an oversize hole for the tractor pin (the oversize will allow some movement of the toplink). :-)
dan harrison
06-18-2003 05:11:41
 Re: Re: case top link in reply to mj, 06-17-2003 14:49:51
thanks mj, I'll give it a try.
