Case w3/580 losing power on hills
EddieG
06-16-2003 18:00:12
Does anyone know how much fluid and what type should be in the 530 torque convertor? And If the fluid is low, would this cause a lack of power? And should fluid come out of the starter?
Gary
06-23-2003 14:55:11
 Re: Case w3/580 losing power on hills in reply to EddieG, 06-16-2003 18:00:12
My manual says 12 quarts. I just recently changed out my fluid with Dextron III, but my pressure dropped from 100 to 80. I talked with the Case mechanic and he told me to put in the Hy-Tran. I ended up using Champion 4000 from the local Farm & Home. This is a 10w20 Oil. The Dextron is 5w20. This oil helped, but I'm still @ 90psi and dropping to 70-75 when the oil is hot. I may have another problem...As for the starter, mine leaked too, I bought a gasket for less than a dollar and fixed it. Too low on fluid could cause the torque convertor to slip. I have the same problem with low pressure...
