HELP, with carb settings
Richard
06-15-2003 07:17:07
I have a 41 SC that I rebuilt the carb. It wont run without the choke being on. That's why I rebuilt it. Do I have an air leak in the gasket?
(Carb mounting, manifold) the settings are 1 1/2 turns out from set for idle and power are they not? Thanks Rich
Mike Schotte
06-15-2003 08:38:05
 Re: HELP, with carb settings in reply to Richard, 06-15-2003 07:17:07
Rich,
Here are the settings for the model SC Zenith 9667A (05771AB) carburetor. Since this question comes up from time to time- I thought I'd type this info in so it can be referenced in the archives. Hope this helps.
(FROM THE CASE MODEL 'S' SERIES OPERATOR'S MANUAL) Float level:
1-5/32" (+/- 3/64") from surface of upper casting to bottom of float in closed position (turned upside down)
Idling adjustment:
Adjustment for idle speed and idle mixture can best be made together and should be made with the engine warm. The throttle level on the seat mounting bracket should be all the way forward before making the adjustment. The idling speed screw 1 (Fig. 12) (which is the screw on the side of the choke butterfly) should be adjusted so that the engine will idle fast enough to prevent stalling. Then turn the idling jet adjusting screw 1, Fig. 12 (which is the top screw with the spring) in or out until the engine runs smoothly.
A good starting point for the adjustment is ONE FULL TURN from the idling needle valve seat because the correct setting is usually between 3/4 and 1-1/4 turns open.
Main jet adjustment:
This adjustment should be made when the engine is warm and working under load because it exerts the greatest influence under those conditions. Turning the main jet 3, Fig. 12 (the T-handle jet on the lower bowl) inward provides a leaner mixture, while turning outward produces a richer mixture.
Turn the valve inward until the engine starts to miss or power falls off. Then turn outward until the proper operation is secured- about 1/8 of a turn is usually sufficient. This setting will assure maximum fuel economy with very nearly maximum power.
If the engine will not run with the original setting, make and approximate setting as follows: Turn the main jet valve inward until the needle just seats. Use great care not to force the point against the seat as this may ruin the seat. Next turn the valve outward TWO FULL TURNS. This setting is sufficiently close so that the engine can be operated until final adjustment is made.
Loss of power and spitting through the carburetor indicates the mixture is too lean. This is especially evident when the engine is accelerated by pulling lightly on the throttle rod. An overly rich mixture is indicated by sluggish action of the engine and by the appearance of black smoke at the exhaust. The final setting should be as lean as possible and still have satisfactory engine operation and power.
O.K.- that's enough typing for me!
-Schotte
Tractor Tom
10-06-2003 18:29:17
 Re: Re: HELP, with carb settings in reply to Mike Schotte, 06-15-2003 08:38:05
Thanks for the info Mike! That's exactly what I needed!!
Richard
06-15-2003 15:49:10
Thanks Mike
Rich
mj
06-15-2003 15:03:56
Mike, this should go to the 'Tune Up Guide' section so you won't have to type it again....how about it , Kim? :-)
Mike Schotte
06-15-2003 21:22:49
 Re: Re: Re: HELP, with carb settings in reply to mj, 06-15-2003 15:03:56
Hey mj,
I've slowly been putting some info into posts in the CASE forum for the common questions that get asked all the time. That way I can just do a quick archive search and then link somebody to the info.
It's a lot of typing at first- but I'm convinced it saves time in the long run...
Of course, my knowledge is limited to the SC. I love to hear info on other models from the guys who have turned a lot more wrenches than I have... (I bet they know better cuss words than I do, too!)
-Schotte
mj
06-17-2003 15:12:40
 Re: Re: Re: Re: HELP, with carb settings in reply to Mike Schotte, 06-15-2003 21:22:49
I admire your tenacity, my friend! Somedays my carpals and tunnels just ain't up to it! I've got quite a bit of old, original Case info that I've collected (my VA manual has pictures of the VA Eagle rockshaft housing on a fabricated mount which is attached to a pre-Eagle transaxle housing. Case must have done this in order to get the manual printed without having to wait for a production housing. I also have a page from an early dealers' parts catalog that shows the add-on three-point for pre-Eagle tractors.). I am tempted to cut up the manual and scan it, but....the idea makes me cringe! I believe that you are on the right track in preserving as much old info as possible and making it available on the web since 'old Cases never die' and 'old Case NUTS need DATA!'. :-)
