Larry or Anyone Engine # from 800,800b,830 I hope
Cyric
06-14-2003 14:01:29
Ok finally had to go get the # dad Just couldent find it :) but i can see why with the nice coat of gunk
So can anyone tell me wht this engine is
here is the #
8146990
So what is it ???
and what is the # for a head gasket,set,upper gasket set for the darn thing :p
Also any idead on where i could get the head gasket fairly cheap online.?? :)
Thanks All Joe
kennyp
06-15-2003 07:29:11
 Re: Larry or Anyone Engine # from 800,800b,830 I h in reply to Cyric, 06-14-2003 14:01:29
I would just mention here that Case combines, forgot the exact models, used the "800" engine. Mine has the larger bore of the 830. I bet a lot of them have been swapped. I save mine just in case I ever need it.
Larry
06-14-2003 16:43:45
Dales right. The number does correspond with the 1959 900. It also belongs to the 1959 700B and the 800B. Was this engine on a 400? If so I have a Frankenstein too. My 400 has a engine block from a 700B or 800B, and the sleave and pistons from a 830. That gives it 301 c.i instead of the 251c.i it originally had.
As far as the gaskets go,you should be able to get the from a Case-IH dealer. That or get in contact with Don L. He's on this board every so often.
Cyric
06-14-2003 21:00:19
 Re: Re: Larry or Anyone Engine # from 800,800b,830 in reply to Larry, 06-14-2003 16:43:45
Hum Larry thanks for the info....this engin is on an 830 chassis...rather odd though :(
DAle in Tx.
06-14-2003 15:16:22
Hi Joe Looks like A 1958 900 from my book.is it a 6 cyl. standard ???? Dale In Tx.
Cyric
06-14-2003 15:28:16
 Re: Re: Larry or Anyone Engine # from 800,800b,830 in reply to DAle in Tx., 06-14-2003 15:16:22
Dale
no it is 4 cyl. :(
