David brown 885
leonard
06-13-2003 06:50:11
looking for information on whether a 3 cyl gas engine can be changed to a desil and if the deseil will bolt right up
Elmer
06-14-2003 12:03:20
 Re: david brown 885 in reply to leonard, 06-13-2003 06:50:11
I have a cylinder head.
Tim Pennell
06-14-2003 13:49:58
 Re: Re: david brown 885 in reply to Elmer, 06-14-2003 12:03:20
Elmer does that 885 take the same pistons as a 990? If so I have three used pistons for the chageover.
Tim
correction 885.....pistons take same as 990?
Elmer
06-15-2003 06:26:01
 Re: Re: Re: david brown 885 in reply to Tim Pennell, 06-14-2003 13:49:58
no the 990 only had a 4 inch stroke.
Tim Pennell
06-14-2003 13:49:10
Elmer does that 880 take the same pistons as a 990? If so I have three used pistons for the chageover.
Tim
Elmer
06-13-2003 18:09:10
The three cylinder gas engine was originally the diesel. It can be changed back to diesel. You need pistons, diesel cylinder head, injection pump and drive gear, injectors. You may also need the fuel tank. I think the gas tank is different. I have never done one but i think it is possible.
Tim Pennell
06-13-2003 21:30:12
 Re: Re: david brown 885 in reply to Elmer, 06-13-2003 18:09:10
If it is like my 4600 converted to an 880 diesel the tank had the return line fitting on it, just had to remove the plug and hook up the line. I took a complete 880 and everything bolted up perfect except it requires a different waterpump. Needed a niple on the top rather than a rubber washer to connect to the head. You also need the diesel 2 blade fan and the diesel 90 amp starter.
Tim
elmer
06-14-2003 05:14:46
 Re: Re: Re: david brown 885 in reply to Tim Pennell, 06-13-2003 21:30:12
I have an 885G gas tank here and there is no provision for the return line. How are you doing Tim. Long time no hear.
Tim Pennell
06-14-2003 08:06:55
 Re: Re: Re: Re: david brown 885 in reply to elmer, 06-14-2003 05:14:46
Been busy, still lurk on the boards when I get a chance. Got elected to our local government last fall so between that and a full time job my hours are pretty well filled up. Never did fing that O-ring part number for you, lost the bill somewhere. :( Hope all is well out your way.
Tim
chrysler32
06-14-2003 07:06:05
wahnt to thank everyone for comments now if can just get everything changed ove will get good thanks leonard
