Case VAC Steering Adjustment
Billy Adams
06-09-2003 20:12:11
Hi All,
I'm trying to tighten some play in my steering on my '52 VAC. Paragraph 2B on page 6 of my JI Case Shop Service manual by I&T says to "slowly rotate steering worm sleeve which is eccentric, while checking amount of gear backlash". I don't understand how this works. I find center like it says, & rotate the steering worm sleeve, but all it does is either turn the wheels, or push the ball bearing, race, & cage out the front. It never "tightens" up or meshes the gears. What am I missing here? In road gear the tricycle front end wobbles & when jacked up I can move the horizontal spindles about 1/2 inch measured at the end of the axles. I replaced the wheel bearings in the wheel hubs & they are good & tight, now I want to take the play out of the steering gears.
Thanks,
bja
