Hitch on Case 730
R. Smith
06-09-2003 10:07:55
I own a Case 730 (731??) which has an Eagle Claw hitch rather than a conventional 3 pt. hitch. This hitch allows no "swing" from left to right. When linked to a typical set of mounted 4 btm. plows the lack of a flexible link between the plows and tractor make it impossible to turn when the plows are in the ground.
The repair manual I have seems to suggest it is not an option to convert the tractor to the 3 pt. hitch setup, even if one could be located, since it appears nearly everything is different on the tractors using these two types of hitches. Can this conversion be done?? Any suggestions would be welcome.
Bart850
06-12-2003 17:57:27
 Re: Hitch on Case 730 in reply to R. Smith, 06-09-2003 10:07:55
Well.. I just bought a 1960 731 and here is the three point setup on it... works real good too! If you want more detailed pics let me know.
Marc
INCase
06-10-2003 05:27:21
alot of the components to convert could be bought at a farm supply place like TSC. some garage engineering will need to happen to get things to work but it is possible.
george md
06-09-2003 21:07:16
R.SMith,
I have a 730 eagle hitch and the 4 bottom semi-
mount plow to go with it . the plow has a pivot where the crossbar connects to the plow frame , works well.
george
Jim M
06-09-2003 15:11:32
Anything can done with enough money. If you want to convert it I would find a set of lift arms off of another tractor that has 3-point lift and are the same length or longer and get the rods that go up also. You may have to cut off the inner swivel balls and change to the pin size on the 730 or to shorten to the correct length and install spacers to keep them from sliding side to side. You may get by not installing balls on the up rods but try first and see if they binde up. You will have to have some sort of side motion limiter also. Chains with turnbuckles from the lift arm to and axle anchor point should work well.
turbo
06-09-2003 10:26:05
Case built plows during that era is how they solved that problem.
