Case Vac Hydralics
Scott
06-08-2003 21:48:30
Bought a Case Vac. Last Summer Hydralics were working used a hay spear on it. They started getting sluggish in the fall. Now won't work at all. Anyone know what I can do or what might be wrong? Thanks!
Minn. Norske
06-09-2003 10:13:13
 Re: Case Vac Hydralics in reply to Scott, 06-08-2003 21:48:30
Those round bales are little to much for that system. You probably blew the seal on the piston on the lift arms!
Joe (Wa)
06-09-2003 13:21:09
 Re: Re: Case Vac Hydralics in reply to Minn. Norske, 06-09-2003 10:13:13
Pull the leakoff tube on the lower right side of the cylinder, you'll figure out pretty quick if the cup is leaking by. If the tube is plugged with grease it is from overgreasing the center rock shaft bearings and will cause an air lock. The piston is designed to lift anything up to the relief valve setting, travel bouncing is another matter. Good luck, Joe
Mike from Canada
06-08-2003 23:38:53
what kind of pump do you have? is it off the pulley or the engine?
Scott
06-09-2003 07:50:49
 Re: Re: Case Vac Hydralics in reply to Mike from Canada, 06-08-2003 23:38:53
Mike the pump is off the engine
Mike from Canada
06-09-2003 08:14:52
 Re: Re: Re: Case Vac Hydralics in reply to Scott, 06-09-2003 07:50:49
try checking the oil level inside the torque tube. it normally takes 2 gallons of fluid but but may take more w/ the use of a loader. if you have a late model VAC (1951-1955) you may find a hydraulic filter in the torque tube. replacements are easy to come by through NAPA or CaseIH. theyre just expensive.
if your tractor has no filter, it may be more serious.
mike
