Tachometer for DC
Paul f
06-08-2003 06:48:16
At some point in her life my DC3 had her mag replaced with a right angle Delco distributor but she is still 6 volts. I was thinking (while mowing) it would be fairly simple to hook up a tachometer to the coil. Then I stared looking for a tach. Problem is virtually all are for 12v (some are 24v for boats) and most go up to 8,000-11,000rpm for a range. With redline for a DC of 1,390 rpm it would be a little hard to read the scale on the ones I have seen. Has any one found a source for a 6v low speed tach?? As a thought (also while mowing) if I used a 12 v tach would the reading be doubled, halved or just not work at all???
Thanks Paul f
C. Amick
06-10-2003 09:27:09
 Re: Tachometer for DC in reply to Paul f, 06-08-2003 06:48:16
You could probably find a mechanical tach for an old Farmall that would work. I have a IH distributor off a Farmall that has a connection for a tach on it. They were probably on the 300 and 400 series Farmalls.
klyde
06-09-2003 04:51:56
Go to an automotive speed shop. I had a Sun tach on my drag car for years that had its own batteries inside. Car had a big hemi with a mag and no battery on board.
laipuller
06-08-2003 15:43:16
i have a solution, find a distributor with a tach drive for a 350-450 farmall. it will bolt right on, and you can use a mechanical tach solving the electical problem.
John Saeli
06-08-2003 10:20:32
Paul; Search the junk yards for that 6V tach. My '54 Dodge truck has a 6V tach.
Mike Schotte
06-08-2003 06:58:37
Paul,
Just out of curiousity- where did you get that redline RPM figure for the DC engine?
I think I've seen "factory spec" RPM figures listed in the Owner's Manuals before... but I can't remember ever seeing redline specs.
I guess the answer to your tachometer question might be the same as what people do to use a 12V timing light on a 6V electrical system.
I can't remember what the answer was- but I've seen it discussed from time to time on the various tractor boards. Maybe a search of the archives will help you.
-Schotte
Paul f
06-08-2003 07:04:42
 Re: Re: Tachometer for DC in reply to Mike Schotte, 06-08-2003 06:58:37
Mike: According to operators manual no load engine speed is 1,390 (full load is 1,200 which also yields PTO speed of 540) Maybe redline was not correct choice of words, but for normal operation I don't think you want to exceed the listed RPMs. Paul f
