Parking Brake
Paul
06-07-2003 21:41:54
I have this David Brown 990 which I need advice how to fix the parking brake . I notice that the shaft which has the teeth on which seem to be ok but it passes through this small housing which I assume should have something on so when you turn it it holds the brakes on but this case no amount of turning will hold it. Is there a pin broken ?worn or is the housing got some splines that are worn?. As I cant see any thing there.
Anyone with a pictorial diagram please?
Paul
06-08-2003 12:00:27
 Re: Parking Brake in reply to Paul, 06-07-2003 21:41:54
Per your request, we just wanted you to know that the message you posted
> with the subject of "Parking Brake" in the Case Tractors Discussion
> Board has received a reply.
I got this in my email but unable to see wher the reply is tried to reply to email recieved but it bounced so therefore posting this here.
P.S what does the knob do on the front of the housing for the Parking brake?
Elmer
06-08-2003 16:34:14
 Re: Re: Parking Brake in reply to Paul, 06-08-2003 12:00:27
That knob is the rate of lower for the 3 point hitch. Turn it clock wise and it will slow the fall of the hitch. Turn it opposite direction and hitch will fall faster. Makes a difference on implement weights.
Paul
06-09-2003 01:29:48
 Re: Re: Re: Parking Brake in reply to Elmer, 06-08-2003 16:34:14
Hi Elmer
Thanks for the advice on the knob on what it does. Had a bit of a idea it had something to do with hydralics as only just bought this tractor a few days ago.
Still cant find the reply to my query about parking brake thought.
Thanks again.
Elmer
06-08-2003 04:56:56
There is a pawl inside the housing that is wore out. The easiest way is to remove the whole assembly and put it in a vice and change it. I have them in stock. If you need more assistance email me.
Paul
06-09-2003 01:34:54
 Re: Re: Parking Brake in reply to Elmer, 06-08-2003 04:56:56
I have found your reply. I took the cover off but couldnt see a pawl anywhere.
Is it buried out of sight
or did someone remove it?
Do you have a picture of it?
Thanks again Paul
P.S im in New Zealand
Elmer
06-09-2003 09:56:42
 Re: Re: Re: Parking Brake in reply to Paul, 06-09-2003 01:34:54
You have to remove the pull rod to get the pawl out. It is fed in from the side of the housing and passes through the rod bore and into its own bore. Like i meantioned in the last post it is easier to remove the whole quadrant from the tractor and mount it in a vice. Do you need manuals?
Paul
06-11-2003 02:53:26
 Re: Re: Re: Re: Parking Brake in reply to Elmer, 06-09-2003 09:56:42
Hi Elmer
Thanks for the advise. I wondered where it was.
I was going to pull the pull rod out but the roll pin at bottom is stuck so I soaked some CRC for a few days hoping it will free up. Looks like there has been no lubrcation here for some time. Will have another look this weekend coming weather permitting.
Yes some Manuals would be usefull but the trouble im down in New Zealand.
Thanks again.
Paul
07-09-2003 03:03:15
 Re: Re: Re: Re: Re: Parking Brake in reply to Paul, 06-11-2003 02:53:26
Hi Elmer or anyone else.
I pulled the roll pin out finally and removed the rod and pulled it out but no sign of pawl I noted a hole near bottom on angle but no sign of anything in here. Is there a spring and a pawl that is round to fit this hole ????? I assume it fits here.
Whats the grove near top of hole for??
Anyone around with a pictorial diagram please.
