VAC 14
PMTOOLBOX
06-03-2003 23:10:39
I overhauled my VAC, new sleeves, new rings reground crank, bearings, etc.Runs fine. Problem is manuel calls for 20 lbs of oil pressure and all I get is about ten. Tried a couple of guages and get yhe same reading. Any Ideas? Thanks
C. Amick
06-04-2003 05:39:01
 Re: VAC 14 in reply to PMTOOLBOX, 06-03-2003 23:10:39
Is the oil stem in the filter housing? It's the stem that runs up inside the filter. If that's not the problem, it must be the oil pump.
OR
06-04-2003 09:40:58
 Re: Re: VAC 14 in reply to C. Amick, 06-04-2003 05:39:01
relief valve or cam bearings
Jim M
06-04-2003 17:20:43
 Re: Re: Re: VAC 14 in reply to OR, 06-04-2003 09:40:58
The book calls for reconditioning the spring in the oil pump. I've done this several times and works fine
mj
06-06-2003 14:25:00
 Re: Re: Re: Re: VAC 14 in reply to Jim M, 06-04-2003 17:20:43
Yeah (free length should be 1 and 15/16 ....call it 2 inches), and check the clearance between the cover and oil pump gears...should be .0035 to .0065....change gasket thickness or mill cover to get the clearance that you want. :-)
mj
06-06-2003 14:28:31
 Re: Re: Re: Re: Re: VAC 14 in reply to mj, 06-06-2003 14:25:00
Check the 'mill cover' should be 'mill the HOUSING' to reduce clearance BUT a thinner gasket is easier if it will give you the .0035 to .0065! :-)
