Hey Alberta Mike, naked women!
SHeiserman
06-03-2003 20:27:15
I see your approach of simply asking about CASE-O-MATIC isn't getting you anywhere, so let's try this. I find it hard to believe no one here knows anything about it. I'm not a farmer or a mechanic, but I have an 830 C-O-M. It still runs and works great. I bought it to move snow, so I don't do any heavy work with it. It goes like this: the people who have actually used C-O-M speak highly of it. Those that haven't, don't. Once you get on to how it works, I for one think it's pretty slick. All I've ever bought for this tractor was brakes, filters, and batteries. Never had to do anything major, so I can't tell you about parts availability.As far as C-O-M goes, here's what I think I know. You always start and stop in C-O-M. Once the tractor is moving, put it in direct drive. If the going gets tough, drop it back into C-O-M. Doing that will decrease ground speed while engine speed is unaffected. If done correctly, C-O-M provides a smooth take off from a standing start, and tractor can be stopped by pushing on the brakes without touching 'clutch' pedal. That's the long and short of what I know. Now, maybe someone who knows more (and thought this would be about naked women) will elaborate in more detail. Good Luck.
David Bacon
06-06-2003 20:36:09
 Re: Hey Alberta Mike, naked women! in reply to SHeiserman, 06-03-2003 20:27:15
I grew up on C O M and it works well for field work. Dad bragged about it alot on many ocasions, but us and the neighbors thought it was a major pain in the rear when involved with pto field work. For instance on a bailer that was pto driven and you came to a big wad--and at times there were lots that you actually had to stop for, then inch forward. Let me make a comparison--your automatic transmission in your car---now run the foot feed at full throttle--in low gear--now take the transmission out of gear---this is the same as pushing in the clutch. Now that you have stopped your ground speed just try to move your car forward a foot or two. This must be done at full trottle to keep the bailer in motion. There is no clutch--it is a valve that is open or shut--no in between. This again would be like dropping your car transmission in gear at full throttle. See you should throttle down before starting forward motion (at a slow iddle) IT JUST DID NOT WORK AT ALL compared to say a standard transmission Case with a live pto. As far as field work without PTO or any pto work that was start and go for a long time with out stopping it was a great idea.
SHeiserman
06-07-2003 00:36:49
 Re: Re: Hey Alberta Mike, naked women! in reply to David Bacon, 06-06-2003 20:36:09
That's the first time I've heard an honest disadvantage of the system from someone who's actually used it, as opposed to all the perceived problems from people who haven't.
John McLean
06-05-2003 18:52:49
I agree completely. I have a 411B and learned how to drive on C-O-M. As long as I idle it down completely before shifting, and disregard a little gear clash, I have never had a problem. I have a hydraulic Triumph (now Alamo) sickle bar on the side. I can just tap the brakes when I hit a thick patch of grass and never have to touch the clutch or the throttle. I would not trade it!
Chris Vangel
06-05-2003 03:33:26
Hey, wait a minute, there aren't any nekkid women here. It's the old bait and switch! If I knew anything about a Case-O-Matic I'd be happy to tell you, but I don't know any more than what the original post stated. And for the record, I probably know even less about women!!!! It was a pretty good attempt though. Good Look. Chris Vangel.
todd
06-06-2003 18:09:54
 Re: Re: Hey Alberta Mike, naked women! in reply to Chris Vangel, 06-05-2003 03:33:26
All I know is that Dad had a 42 SC with a hand clutch that went into gear everytime and Uncle Mike had an IH 706 (the big nice tractor on the farm) that we lovingly referred to as that "gear-grinding hard-shifting *%#!*" that would go into gear after you clutched and grinded it three or four times. Reving the RPMs up and down sometimes helped. GO CASE!
