VC in IL
Mike from Canad
06-03-2003 15:42:12
the price is right but im a little too far removed from the country to pick it up. its been updated some but the paint looks better than my neighbours corvette.
feast yer eyes!
mike
Alberta Mike
06-05-2003 04:54:09
 Re: VC in IL in reply to Mike from Canada, 06-03-2003 15:42:12
Nice little tractor, I'm not sure whether I like the Ford N exhaust system on it, but still a nice little tractor. I wonder what the reserve is on it, nobody's going to get it for $400. There is a not-too-bad looking adjustable wide front VAC in the photo ads about an hour from here. I might drive out and check it out for a friend of mine. I've never seen one of that type of VAC up in these parts. Meanwhile, I've got to bolt up a front rim/tire on my V and then maybe get the tractor split in half this weekend.
Mike from Canada
06-05-2003 07:52:41
 Re: Re: VC in IL in reply to Alberta Mike, 06-05-2003 04:54:09
yikes. splitting the tractor! is it exploratory investigation, or exploratory surgery (i.e. frozen clutch)?
may the force be w/ you
mike
Alberta Mike
06-05-2003 13:19:34
 Re: Re: Re: VC in IL in reply to Mike from Canada, 06-05-2003 07:52:41
Well, a type of major surgery I guess you'd say. Clutch feels a bit stiff but I think it might be the pedal/shaft being a bit seized. Engine is frozen shut and broken out by some previous Alberta winter. I've got a replacement engine from a MH swather (early 60's so it's all 12 volts with a generator) and I'm pretty sure I'll bolt that one up. Needs a lot of work but hopefully I've got nothing but time.
Mike from Canada
06-06-2003 14:22:36
 Re: Re: Re: Re: VC in IL in reply to Alberta Mike, 06-05-2003 13:19:34
just in case you need parts for your project this guy has this thing back on the auction block. he says its good enuff for parts he doesnt think it would be too easy to restore. i think it suffers from stuckengineitis too.
mike
