Help! Case 450B Dozer
Wilson
06-03-2003 07:35:25
Help! Dozer would not crank, changed fuel filters, drained fuel tank, clean lines from tank to injector. Have lots of fuel where fuel line enters injector. Will start and run @ idol for 5 seconds then dies. Crack fuel line on injector, let fuel run and will start and run another 5 seconds then dies. The return fuel line is also clear. Is this the injector? Help!
Wilson
06-04-2003 15:22:00
 Re: Help! Case 450B Dozer in reply to Wilson, 06-03-2003 07:35:25
Thanks for all of your comments. It's the governor retainer clip inside the injector pump.
Jim M
06-04-2003 15:08:39
You can pull the injectors and hook back to the lines outside of the head. Turn it over and see what it looks like. It sounds like the feul rack in the injection pump is stuck almost all the way in the stop poisition.
