Help need dc case info
R.J. Stone
06-02-2003 19:05:49
I was wondering if someone could tell me the width of a dc case and i know it depends on tire size but a few rough guesses would help also need to know how much a dc would weigh. Thanks
Dave_D
06-04-2003 14:25:08
 Re: Help need dc case info in reply to R.J. Stone, 06-02-2003 19:05:49
I know my DC with 38's on it with the wheels dished in and on the narrowist setting will fit between the rails on my 7 foot wide utility trailer.
Mike Schotte
06-02-2003 19:26:54
n/t
-Schotte
Okla,kans Bill
06-02-2003 19:14:11
All case row crop tractors were made, one way or another so that the rear wheels came in and out. On a DC, they slide in and out on the inner shaft. I would guess that their innermost otside distance is around8ft or so, like u said, depending on tires, but they should be 38s. If your hauling an OLD rusted DC, take some BLASTER rust inhibitor and a good set of sockets and breakovers, prybars and sledges, and good sizeds bocks of wood, to beat against the side of the wheel once you have loosened it. Good luck
Paul F
06-03-2003 05:51:31
 Re: Re: Help need dc case info in reply to Okla,kans Bill, 06-02-2003 19:14:11
According to the manual rear width is adjustable from 48" to 84" (that is tire center line to tire center line so you need to add at least 12-14" to get outside to outside measure)... as Bill points out if you are going to go get an old tractor be prepared for a major, major job if you have to free up the rear wheels and move them. Note if you need to get it down to the minimum width you may have to take the wheels off completely and swap from one side to the other to get the concave surface on the inside...if they are calcium filled and have weights ...good luck
caseboy
06-03-2003 11:10:52
 Re: Re: Re: Help need dc case info in reply to Paul F, 06-03-2003 05:51:31
about adjusting the rear tread on a dc, to change the rear center dish just rotate the cast center 180 degrees, don't change sides with it, that is just unneccesary work.
Ken Tabor
06-03-2003 13:17:31
 Re: Re: Re: Re: Help need dc case info in reply to caseboy, 06-03-2003 11:10:52
A model D with wheel weight and calcium in the tires can top 7400 pounds. Minimium is about 4500
I picked one up from south dakota two years ago.
