Gt-25 terratrac
tom
06-02-2003 16:34:52
i'm looking for parts for a gt-25 terratrac can anyone steer mein the right direction?
r_d97
06-03-2003 06:35:34
 Re: gt-25 terratrac in reply to tom, 06-02-2003 16:34:52
What parts are you looking for? Try the link, there are some guys there that might be able to help.
Edward
tom
06-07-2003 09:14:39
 Re: Re: gt-25 terratrac in reply to r_d97, 06-03-2003 06:35:34
i am looking for parts for gt-25. mainly track inks and boxholders for the rollers. i also have some info on the specs for pins and bushings and some general knowledge as well.
Gerry Vaerewyck
11-25-2003 05:46:29
 Re: Re: Re: gt-25 terratrac in reply to tom, 06-07-2003 09:14:39
I searched everywhere when I restored one and could not find the parts you are looking for. The only track parts I found in one junk yard were unusable.
Track links can be made from 1/2 steel plate. Cut out the general form and give it an offset bend to follow the original shape. The links are stronger if you leave them solid and don't make them look like an "8". You can tap and thread 3/8-16 holes into the edge to hold the track plates. Roller holders can be made from 1" plate with a hole in it. With a little grinding to follow the original shape, it is indistinguishable from an original unless you look really close.
If you still have the links but they are broken, you can repair them with high nickel welding rod and grind back to the original shape. I use my gt-25 for real work and have not had a single repaired link fail.
