Case VAC power problems
Jim R.
04-19-1999 23:03:33
I bought a 51 CASE VAC last fall and spent this spring getting it running. I rebuilt the carb, rewired the electrical (which has been converted to 12 volt), changed the coil, points, condenser, cap and rotor, plus changed out all the fluids and filters. It runs fine, but I seem to have a power problem when backing and going up even the slightest hill. The engine bogs down and dies. Any suggestions as to what might be the problem. Also, I was running it today in 58 degree weather w/a slight rain and the intake manifold was actually icing??? Again, any suggestions?!?
David Davis
04-23-1999 13:12:16
 Re: Case VAC power problems in reply to Jim R., 04-19-1999 23:03:33
Sounds like a fuel problem.Check sediment bowl and see if your getting good flow.Every old tractor if got the sediment bowl was grown up where it screws into the tank.Its a good idea to steam the tank out with degreaser(gets rid of the old gas build up)My VAC had the same problem.As for the iceing it natural,you should see my Case LA when it starts.400+ cid 4cyl it gets the intake white with frost.
C. Amick
04-22-1999 10:03:41
Does the governor move the throttle linkage between the carb and governor when the engine starts to die? The governor has steel balls in it that have been known to stick. Could you have set the float too low? The specs call for a quarter inch between the float and the upper body (at the closest point) with the float in the full up position.
Ossie
04-23-1999 18:55:51
 Re: Re: Case VAC power problems in reply to C. Amick, 04-22-1999 10:03:41
You may want to check the timing -- read the other responses about fuel and they could be correct also but no one has mentioned the timing. My vac ran with much more power with the timing set correctly and I move the timing up after cranking if I am doing a tractor pull which will give you a little more horsepower. Good luck with it .
