SC serial #504020
Les...fortunate
06-02-2003 12:34:05
No, I didn't leave out a digit. That is the #. It has no Eagle hitch. Has a hand clutch.
What year is it?
Mike Schotte
06-02-2003 13:38:02
 Re: SC serial #504020 in reply to Les...fortunate, 06-02-2003 12:34:05
Les,
Is the same number on the block flange? I've heard (but can't confirm) that on the later serial numbers the "80" wasn't stamped onto the block- just the batch number series.
But that would leave a 5-digit number, wouldn't it?
You also said it doesn't have the Eagle Hitch... so I'm confused as well.
I just thought I'd ask for a comparison of the two serial numbers- since sometimes the first number on the dash tag gets buried under the screw.
-Schotte
Paul f
06-02-2003 14:24:12
 Re: Re: SC serial #504020 in reply to Mike Schotte, 06-02-2003 13:38:02
Mike: I can confirm that for some of the 80 series numbers the 80 was not stamped on the engine flange just the model and 5 digit number In my case DC25000.
Les... could your 5 on the flange be an "S" for a model and 5 digit serial be 04020?
Les...fortunate
06-02-2003 14:53:00
 Re: Re: Re: SC serial #504020 in reply to Paul f, 06-02-2003 14:24:12
I knew I should have taken a picture of that tag. Didn't look on the flange. The 5 is well to the left on the tag but I'm 99% sure that there isn't another number buried under the screw. I guess if there is, it would have to be another 5, wouldn't it.
I have looked at this one before and talked to the owner once. With a few exceptions, it is in the best shape of any that I have looked at. It certainly has more paint than all the others put together. Has a flapper on the exhaust which is a real good sign. But I know it hasn't run for several years.
