Where do I put hyd. oil in 1070
Jeff Mans
06-02-2003 11:00:36
The hyd. lift wont work on my 1070, lifts about half ways then stops. I cant find the correct place to put in new hyd. oil....I have a pretty good idea, but dont want to take chances. I just had a loader on it and it seemed to work fine then. Any help would be appreciated.
fire chief
06-08-2003 07:42:53
 Re: Where do I put hyd. oil in 1070 in reply to Jeff Mans, 06-02-2003 11:00:36
standing behinde the tractor the fill is on the left hand side next to the hydraulic pump,,which is the almost flat plate on bach of rear end housing has lines going into it. There should be a plug with a ring you stick your finger into to pull the fill cap off. up in the upper left hand side. You fill till you see oil in the upper sight glass on the left hand side of tractor right by the left hand brake housing.
Shane
06-02-2003 15:13:20
Left side of rearend near the pump there is a dipstick that goes into an elbow that goes right into the rearend. Maybe it is the right side, I don't know without looking but it is the only place back there.
