Vac hyd filter
Joe (Wa)
05-31-2003 22:31:30
Anyone have a current part number for this filter? Old Case nr is vt3139, local dealer can not ID. Thanks, Joe
Don H
06-01-2003 19:02:41
 Re: Vac hyd filter in reply to Joe (Wa), 05-31-2003 22:31:30
Current filter number is A30411.
Joe (Wa)
06-01-2003 20:59:20
 Re: Re: Vac hyd filter in reply to Don H, 06-01-2003 19:02:41
Hi Don, I picked up this nr in the archives and crossed it @ the Wix (33470)& Baldwin (BF1178) sites and it came up as a valid Case part nr but was a plastic encapsulated fuel filter. Did you order one from a Case dealer with this number? Thanks, Joe
Mike from Canada
06-01-2003 14:09:31
which dealer? CaseIH or NAPA? i know my NAPA dealer has no numbers before 1955 anymore but you could try 200 series parts, they match up for the most part.
if its your CaseIH dealer that has no reference to part #'s try a dealer that used to be a Case dealer not an IH dealer. they have a better idea of what your after. some of those IH boys have no clue about old Case parts.
keep in mind these filters are costly!
good luck!
mike
Joe (Wa)
06-01-2003 20:34:35
 Re: Re: Vac hyd filter in reply to Mike from Canada, 06-01-2003 14:09:31
Thanks Mike, the 200, 300 and several of the other nr series tractor cleanable filters are the same diameter but an inch or so longer. I guess I could trim one down but the new replacement filter for these tractors (G13113) appears to be the paper cartridge type (dealer's pix). As for "REAL" Case dealers in western WA, there are none. Joe
