Hey Denny Hoover!
Mike from Canad
05-30-2003 15:06:38
did you manage to get your wiring problem figured out? you never did get back to me about what charging system you had.
was cruising around e-bay and found something quite striking. i hate to tell you but... as flawless as the paint is on it, its the wrong colour. Case Cs were painted dark grey w/ red wheels. looks fantastic though! i really like the colour you painted it!
mike
Denny Hoover
05-30-2003 18:54:22
 Re: Hey Denny Hoover! in reply to Mike from Canada, 05-30-2003 15:06:38
I'm not real sure on the Case myself. I didn't paint it. I have had Case guys tell me gray and other tell me that some of the later ones came our Flambeau Red like this one. I really don't know much about Case's.
The VAC has a 6 volt system but is missing the wiring from the generator to the amp guage to the battery. Can you tell me what it is supposed to look like? Thanks for your help.
Mike from Canada
05-31-2003 13:30:28
 Re: Re: Hey Denny Hoover! in reply to Denny Hoover, 05-30-2003 18:54:22
hmm. lets see if i can draw one.
///-{battery}+--]start sw[---(S)-///
. . . . . . . . . . . .\. . . . . . . . . . /--]cutout[--(G)-///
. . . . . . . . . . . . \--(ammeter)--]light sw[--(L)-///
. . . . . . . . . . . . . . . . . . . . . . \--]ign sw[--(coil neg.)
now thats the best i can do w/ limited info.
i need to know if you have coil/mag ign., cut out or regulated generator, and the serial # might help too (or year).
let me know if this helps.
mike
Denny Hoover
06-01-2003 05:30:05
 Re: Re: Re: Hey Denny Hoover! in reply to Mike from Canada, 05-31-2003 13:30:28
That well help it has a coil and it has a 12v generator.I have no tag on the tractor for the sin# but I was told it was a 1948.
Mike from Canada
06-01-2003 06:12:33
 Re: Re: Re: Re: Hey Denny Hoover! in reply to Denny Hoover, 06-01-2003 05:30:05
12V eh?
maybe you have an alternator not a generator. if its an alternator (like a Delco) the greem wire off the plug is the field wire and that goes to the ign switch. the larger cable on the back goes to the ammeter. the white wire off the plug is for an indicator light that would show if the system wasnt charging. its not used in this application, unless you want to wire a light into your dash panel.
good luck!
mike
p.s. this may help too
Oops
06-01-2003 06:20:28
 Re: Re: Re: Re: Re: Hey Denny Hoover! in reply to Mike from Canada, 06-01-2003 06:12:33
sorry, doesnt work.
lets do it this way.
mike
John H-WI
05-30-2003 15:40:08
Mike,
No matter how you cut it the CC's look better in the proper color. Farmall red just don't cut it!
Bob
05-30-2003 16:58:07
 Re: Re: Hey Denny Hoover! in reply to John H-WI, 05-30-2003 15:40:08
I agree with John, it just does not look right!
Les...fortunate
05-30-2003 18:55:29
 Re: Re: Re: Hey Denny Hoover! in reply to Bob, 05-30-2003 16:58:07
Yeah, but you gotta admit, that cat's tail is a nice touch. 'Bout the color the tractor should be.
John H-WI
05-31-2003 15:21:29
 Re: Re: Re: Re: Hey Denny Hoover! in reply to Les...fortunate, 05-30-2003 18:55:29
Les, a CC has to be gray. A true Case man wouldn't paint one this color to put in a parade or follow Casepower down the track!
DW
05-31-2003 15:56:24
 Re: Re: Re: Re: Re: Hey Denny Hoover! in reply to John H-WI, 05-31-2003 15:21:29
Nothin' like a little (or way too much) intervention from the correct police.
DW
05-31-2003 21:58:00
 Re: Re: Re: Re: Re: Re: Hey Denny Hoover! in reply to DW, 05-31-2003 15:56:24
Sorry Les, but that is not my post. Of course you know that I'm sure from your ISP list you keep on folks. But I'll laugh if you want me to.
Mike from Canada
05-31-2003 19:12:01
i know eh?
could you imagine the uproar that poor Denny would have created if he decided to air brush a couple of flames on it? thank god my dad didnt get to it, he'd have painted it JD green and yellow!
(snicker)
mike
