What have i got ? 800 or 800B ????
Cyric
05-30-2003 12:16:37
Hello all im having trouble identifying what kind of engine i have on this tractor :(
OK here goes
i have a 830 transmsion, rear end, and front end with a 800/800b in the middle of it all (dont ask me how, why it was that way when we got it)my question is what kind of engin is it..ive got a few # from the engin and thee heads in hopes that it will help this is the only one i could find on the engine besides the firing order A1111
and thes where on the heads A6320A & A11800
so what can anyone tell me please i need to put a head gasket on it but dont know what kind to get :) Cyric
DON L
05-31-2003 10:38:36
 Re: what have i got ? 800 or 800B ???? in reply to Cyric, 05-30-2003 12:16:37
YOU NEED, A9235 HEAD GASKET WITH THE ROUND HOLES IN THE CORNERS.
DON L.
Slowpoke
05-31-2003 00:32:35
The 800 is listed as being produced in '58, serial nos for model year '59 included with 700 series.
800B produced in '59 & 60, serial nos seem to be included with the 700 & 800 series, but only '58 and '59 serial nos. No serial nos. listed for 1960.
This info from a dealer's loan and trade-in-value book. Very confusing.
My 801B is many miles from home, but I think A111 is the number cast on the block. 4 1/8 bore, 267 cu. in. diesel.
Jim M
05-30-2003 19:27:41
I don't think they made an 800 only 800B. If the bore is 4.125 it would be a 267 like a 800B or 730. The bolt pattern is different between the two. The 800b has a bypass oil filter and the 730 has a full flow oil filter. They are mounted opposite of each other. I can't remember which is which but I can find out if no one else helps. 1 is vertical and 1 is horizontal. If the bore is 4.250 or 4.3875 its a 830 probably. Gas 830s were 4.250 and 284 cid and diesel were 4.3875 and 301 cid
Larry
05-30-2003 16:46:10
Look on the engine flange where it bolts up to the tranny on the left side.(near the air cleaner) You'll find the serial number stamped into the cast iron there. Give me that number and I can tell you what you have.
