Need help with Case Const King 580CK
TnRabbleRouser
05-30-2003 09:26:36
I am new to backhoes and I need some help with a late 60's early 70's (I'm guessing on the exact year) Case Construction King 580CK. I have found one for sale. The gentleman wants $8500.00 for it. The good things about it, it has a rebuilt starter, converted to a 12 volt altenator, hydraulic cylinders have been recently overhauled, has an operators/parts/maintenance manuals, and it starts and operates with no trouble that I can tell. Now for the not so nice things. All of the bushings in the loader and the boom are worn, headlights are gone, one hydraulic line swedge is crushed and leaking, proofmeter does not work, brakes do not work, antifreeze has a oily feel to it (but no excessive clumps of oil in it). What really concerns me alot is that when it idles and you remove the dipstick, it splatters oil out of the dipstick tube and I noticed oil vapor coming out of the valve cover vent tube. The gentleman sez the oil splatter and oil vapor is normal for a disel (is it and if it isn't, what is it indicating??).
Sorry for the long post, but how much would one pay for it in the descibed condition? I will be using it only for occasional farm use (land clearing).
Thanks for any help offered.
TnRabbleRouser
06-01-2003 05:23:48
 Re: Need help with Case Const King 580CK in reply to TnRabbleRouser, 05-30-2003 09:26:36
Thank you Rod...I think I'll pass on this one for it may be an expensive mistake.
rod
05-31-2003 04:07:50
sounds like head gasket may be gone or possible internal crack in block it is not normal to splatter oil out of the dipstick I have a diesel and it does not do that i would pass on it the pins are just replacement items but you can run into big money rebuilding a diesel.
regards
rod
