Value of 400 Case-O-Matic
INCase
09-27-2006 12:56:14
I found a 400 Case-O-Matic (utility) in a field. I inquired about it for the gage cluster parts for my 800. The owner would rather sell the whole thing instead of parts. I was wondering what it might be worth. It has set for 5-10 years outside with the valve-cover vent/filler open to the weather so I assume the engine may be wrecked. Rears are about 1/2 and one is broke loose from the rim. Fronts are car tires. Many levers & moving parts are stiff or won't move. Sheet metal is straight but the rad cap hole was torched larger and the little doors on top are gone. Wood for battery tray. No drawbar but otherwise all there. Thanks.
Rick Wells
10-03-2006 20:44:57
 Re: Value of 400 Case-O-Matic in reply to INCase, 09-27-2006 12:56:14
I am looking for a hydraulic pump that runs the 3-point for a 1957 Case 400 diesel. If this will interchange and it is sound we could work a deal if you are intrested. Thanks-Rick
INCase
10-11-2006 13:00:40
 Re: Value of 400 Case-O-Matic in reply to Rick Wells, 10-03-2006 20:44:57
Decided to probably get it but haven't gotten it yet. I sent you an email. Thanks.
Triplerange
09-28-2006 05:21:41
I don't know...A couple hundred I guess.
