HELP! Case 800B, Case-O-Matic Problems!!!!!
Jeff Jennifer
05-29-2003 06:00:30
We repair older tractors. Had a call from a gentleman this morning that owns a Case 800B.
The tractor is running, but it won't move! Said
the Case-O-Matic/Transmission has problems. What is the parts availability on fixing this tractor?
Is it worth it?? Who is the best source to get
used or new parts from? We are located in NY.
ANY SUGGESTIONS--PLEASE e-mail. Greatly appreciated! E-mail [email protected] or
(315)-536-1206. HELP!
Jeff Jennifer Jensen
05-31-2003 05:37:37
 Re: HELP! Case 800B, Case-O-Matic Problems!!!!! in reply to Jeff Jennifer Jensen, 05-29-2003 06:00:30
THANKS VERY MUCH FOR ALL YOUR HELP! Greatly
appreciated. Talked to the owner in more detail,
believe he isn't going to fix it. We gave him
a name of a part's yard to contact. He is going
to go from there. He is convinced it is "shot",
and not worth rebuilding due to what he would
have in the tractor after he is done. We have not gone down to look at the tractor, just going
by what he has told us. Yes, know how much
service manuals mean. They are a great guide/
reference. THANKS TO ALL! Happy restoring/
collecting!
Craig M
05-29-2003 23:34:43
The clutch unit itself is a Palmer Johnson unit. I got parts for mine from an industrial clutch place in Minneapolis. They are relatively simple, just orings and piston rings more or less. Mine would move but lockup would not work.
Try John Saeli,
05-29-2003 19:32:34
He is pretty good with these things.
Jim M
05-30-2003 10:04:30
 Re: Re: HELP! Case 800B, Case-O-Matic Problems!!!! in reply to Try John Saeli, , 05-29-2003 19:32:34
You should probably get a good service manual on it. That way you'll understand better what is in there. You should do a pressure test first. My dad got some of the parts for his 800b from Case and some from a Twin Disc dealer
